Salta al contenuto principale
2001 Nissan Sentra Windshield Wiper Blades Replacement
Natalie Aponte
Natalie Aponte e 2 altri collaboratori
Ultimo aggiornamento il March 23, 2023
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
In this guide you will be instructed on how to easily change the windshield wipers on your 2001 Nissan Sentra . Wiper blades should be replaced every six months or as soon as you notice a difference in driving visibility. When wiper blades no longer make contact with the windshield surface, because they wear off, begin to squeak, smear or streak, they should be replaced. If they are used when they are no longer working properly, it can result in poor visibility on the road, and can end up causing an accident. With this guide, you will be able to follow simple steps and easily replace your old windshield wiper blades.
  1. 2001 Nissan Sentra Windshield Wiper Blades Replacement, Windshield Wiper Blades: passo 1, immagine 1 di 1
    • Measure the wiper blades to make sure they are the correct size.
  2. 2001 Nissan Sentra Windshield Wiper Blades Replacement: passo 2, immagine 1 di 3 2001 Nissan Sentra Windshield Wiper Blades Replacement: passo 2, immagine 2 di 3 2001 Nissan Sentra Windshield Wiper Blades Replacement: passo 2, immagine 3 di 3
    • Push the button until it clicks.
    • Lift the lock cover and then push the blade down, rotating it slightly and lift it upwards.
  3. 2001 Nissan Sentra Windshield Wiper Blades Replacement: passo 3, immagine 1 di 1
    • Insert the new wiper blade.
  4. 2001 Nissan Sentra Windshield Wiper Blades Replacement: passo 4, immagine 1 di 1
    • Once the wiper blade is accommodated, close the tab. Pull it upwards to lock it.
  5. 2001 Nissan Sentra Windshield Wiper Blades Replacement: passo 5, immagine 1 di 1
    • All done!
Conclusione
You have replaced the windshield wiper blades on your Nissan Sentra
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 726
