Does your Acer Aspire 5253 laptop no longer turn on? Acer Aspire 5253 laptops are susceptible to a range of problems that could cause them to stop turning on, some of which are simple to fix. Check the following possible causes to identify and solve the problem.
No Battery Power
If your laptop ran out of battery power, it will not show any signs of life until it is charged again. Plug in your laptop’s power cord to the laptop and a power outlet. Wait for a few seconds after plugging your laptop in and check the LED light on your laptop charger to make sure the current is flowing. Allow the laptop to charge for at least two hours, then restart the computer.
No Battery Detected
If the laptop does not turn on even after several hours of charging, there may be a problem with the battery’s connection. If your laptop’s battery pack is not attached correctly, the battery will not charge. Use the Acer Aspire 5253 Battery Replacement Guide to access the laptop’s battery. Reinstall the battery and check that all of the connections are properly installed. Also, check to make sure that there are no bent pins where the battery is placed.
If the battery is undetected by the laptop due to other internal connections, check the Acer Aspire 5253 Motherboard Replacement Guide. Using this guide, check all the laptop’s internal connections to make sure all the wires and cables are properly installed.
Faulty Battery
If you have double-checked all of your battery’s connections and attempted to charge the battery, but your laptop is still not turning on, you may be dealing with a faulty battery. Use the Acer Aspire 5253 Battery Replacement Guide to replace the laptop’s battery with a new one. Then, hold down the laptop’s power button for 20 seconds. Next, reinstall the battery and plug in the laptop’s power cord. An orange charging light should turn on. Once the laptop is charged to a certain point, the orange light will turn blue. Try to turn on your laptop again.
Faulty Motherboard
If you have replaced your laptop’s battery and it still refuses to turn on, you may have a faulty motherboard on your hands. Use the Acer Aspire 5253 Motherboard Replacement Guide to replace the laptop’s motherboard.
Related Pages
- Acer Aspire Has Display Problems
- Acer Aspire Is Overheating
- Acer Aspire Is Running Slowly
- Acer Aspire Has Volume Control Problems
0 Commenti
