Salta al contenuto principale
« Torna a Tutte le Storie
The Missing Hard Drive
stephenjoly99 -
MacBook Pro 13" Unibody Early 2011
Immagine Storia
  • Immagine n.1
  • Immagine n.2
  • Immagine n.3
MacBook Pro 13" Unibody Early 2011 Hard Drive Cable Replacement
25 minuti - 1 ora
Moderate
Il Mio Problema
The problem was that my hard drive was not visible anymore. It wasn't booting properly so I booted to my second HD and it wasn't reading my primary HD (my SSD). Because of this I took it to the apple store to see what they though, took it to canada computers and replaced the SSD and then I saw on the apple support forums that replacing the HD cable fixes the problem.
La Mia Riparazione
So I took to the internet where I found iFixIt and bought the cable from there and managed to fix the problem. The procedure was very easy and my problem was solved. The only hard part was to move my primary SSD from the optical drive caddy back to the primary bay. That took some time.
Il Mio Consiglio
The entire thing was actually very simple, like I mentioned, but I would only recommend doing this is you are 100% sure that the HD cable is the problem. Try to reformat your drives and switch bays to be sure.
Immagine MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable
$34.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 2
Tutti i Tempi: 75
