Salta al contenuto principale
« Torna a Tutte le Storie
Is it possible to change a capacitor?
pirmil -
MacBook Pro 15" Retina Display Early 2013
Immagine Storia
MacBook Pro 15" Retina Display Early 2013 Logic Board Replacement
2 ore
Moderate
Il Mio Problema
Panne complète du MacBookPro. Complete failure, the Mac will not boot!
La Mia Riparazione
Démontage relativement facile. Excepté le connecteur des ventilateurs.
Relatively easy disassembly. Except fan connectors
Il Mio Consiglio
Une question. Est-il difficile de remplacer le composant [68 C3N] qui a brulé ?
A question. Is it difficult to replace the component [68 C3N] who burned?
1 Commento
Totally possible. Take a look on the tutos by Louis Rossmann: https://www.youtube.com/channel/UCl2mFZo...
His videos are so long sometimes but you learn a lot.
Be careful!! If you are not experienced on soldering don't attempt to change this tiny devices. You better practice a bit before doing so.
Alex - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 9
Tutti i Tempi: 330
