MacBook Pro 13" Unibody and MacBook 13" Unibody Fan
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / New / Black
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Silver
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Black
39,99 US$
39,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
Sfoglia il Nostro Negozio
Mai riparato qualcosa? Questo è Genio.
Condividi la tua storia di riparazione con #ImAGenius
Siamo tutti Geni
Dettagli Prodotto
Descrizione
Descrizione
Replace a broken, damaged, or otherwise underperforming fan for your MacBook Pro 13" Unibody (Mid 2010-Mid 2012) or MacBook 13" Unibody (all models) with this part.
L'insieme delle parti comprende
  • Fan
  • Surrounding metal bracket
Video di Installazione
Compatibilità
Storie di Riparazione
Avatar utente
Il Mio Problema
The fan sounded like it was dying.
As I was leaving one day, it started running, and I was sure that someone was outside using a weedeater. Then I remembered it was winter and snow was everywhere, so that probably wasn't the case.
La Mia Riparazione
Pretty painlessly. I read some reviews hearing that it didn't go as w . . .
Avatar utente
Il Mio Problema
I suppose my computer is ancient considering many machines are replaced at 2ish years. Anyway, fan was making terrible clicking/rattling sounds after a suffering a light drop from a low bed onto carpet.
La Mia Riparazione
Easy peasy, lemon squeezy.
Il Mio Consiglio
None. If you know how to use a screw driver, you can make this repair.
Avatar utente
Il Mio Problema
The fan had been making a loud grinding noise. It also couldn't reach it's max RPM.
La Mia Riparazione
It was very straightforward.
Il Mio Consiglio
Be slow and patient; the connectors are very delicate. Also, keep track of the screws!
Avatar utente
Il Mio Problema
Wife's Macbook Pro 13" fan stopped working
La Mia Riparazione
Literally took off the Phillips screws holding bottom cover, took 3 Torx 6 screws out, unplugged fan from board, took out fan, put new one in, plugged into board, put Torx 6 screws back in, and put Phillips back in. Worked like a charm.
Il Mio Consiglio
Screws had tiny bump o . . .
Avatar utente
Il Mio Problema
The fan was getting noisy but still working. I knew its days were numbered
La Mia Riparazione
super easy. While i was in there I decided to upgrade the HD to an SSD also. With the tutorials on Ifixit it was all super easy.
Il Mio Consiglio
Don't be afraid to try repairs on your MacBook Pro. It's much easier than you think with the tutor . . .
Avatar utente
Il Mio Problema
My MBP has been making this grinding noise that I originally thought was the HDD failing (again). Turned out it was the fan going bad. When I ran a YouTube video my CPU temperature spiked to high 80's and you could hear the fan screaming for mercy. lol :)
La Mia Riparazione
The most difficult part of the repair was wa . . .
Avatar utente
Il Mio Problema
The fan had completely quit in my 2012 unibody macbook pro and as a result it was overheating and slowing the cpu to a crawl during taxing graphical work.
La Mia Riparazione
The new fan fit perfectly and works perfectly and silently. I'm far more confident in its brushless motor to hold up.
Il Mio Consiglio
The fans don't come with hard . . .
Avatar utente
Il Mio Problema
My fan was making my MacBook sound louder than a blender!
La Mia Riparazione
Super easy and straight forward.
Il Mio Consiglio
Don't be afraid to make your own repairs. I recently also double the memory sticks on my MacBook and it is now nice and quiet and lightning fast. Having said the, do know your limitations.
Avatar utente
Il Mio Problema
The fan was noisy, and it sounded like it was on the way out
La Mia Riparazione
All good until it came to levering the fan connector out with the spudger. Then -- as predicted in the instructions -- disaster! All four pins from the logic board sheared off, firmly in the fan connector. Fortunately my local computer tech . . .
Avatar utente
Il Mio Problema
The fan was beginning to make a screeching racket and the mac case was getting hotter than it ever had before, then it went quiet and made no noise! So after conferring with a friendMacGuru I presumed that at least the fan could do with replacement immediately lest I need to replace the lot imminent . . .
Mostra di più
