Salta al contenuto principale
Informazioni di riparazione per spaccalegna, noti anche come spaccalegna per legno.
Starting problem with log splitter
TroubleshootIng a failure to start for PowerHorse log splitter
Questa è una buona domanda?
Punteggio 0
3 Commenti:
@dave83837 what model is your log splitter and what engine does it have (if you know)? Exactly what does your engine do when you try to start it?
da
@dave83837 To add on, we are not mind readers, and we certainly are not in your cameras. We need the exact information, excluding anything private, such as the Serial number.
da
Is your log splitter gas or electric?
da
Aggiungi un commento
1 Risposta
What have you checked so far? Does the engine turn over when you pull the starter cord, or is it completely unresponsive?
Start with the basics: check the fuel level, make sure the engine switch is ON, and confirm the choke is set correctly for a cold start. Also check whether the spark plug wire is connected securely.
Punteggio 0
Aggiungi la tua risposta
Dave sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 23
Ultimi 30 giorni: 23
Tutti i Tempi: 23
