Salta al contenuto principale
Rilasciato il 24 settembre 2021, l'iPhone 13 mini è una versione più piccola dell'iPhone 13 di Apple ed è il secondo iPhone mini. È dotato di un display OLED da 5,4 pollici, un processore A15 Bionic e una doppia fotocamera posteriore.
Changing Display and Proximity Sensor
Hi, I have rather a specific issue with this iPhone. It has been given to me as a second use phone and I decided to repair it. From my knowledge the display is a third party item (LCD I think), the touch is likely dead (unresponsive) I do not think something is wrong with the flex cable itself as it seems undamaged to me. And also the connector at the end of the flex cable for Proximity Sensor has 2 pins chipped off.
My question is. Is it worth it to try and bring to a working state? Would buying a new Proximity Sensor fix the unresponsive display? The FaceID?
Thanks for any reply.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
A new proximity sensor won’t fix an unresponsive touchscreen. The touch issue is more likely the third-party display, its flex cable, or the connector on the logic board. I’d test with a known-good compatible display first.
The damaged proximity sensor flex may affect proximity functions, and if the damage involves the original TrueDepth/Face ID components, Face ID may also be affected. Don’t replace those parts blindly; identify exactly which connector is damaged and test each issue separately before spending more money.
Punteggio 0
Aggiungi la tua risposta
Pracovny sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 23
Ultimi 7 giorni: 59
Ultimi 30 giorni: 59
Tutti i Tempi: 59
