Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e sulla soluzione problemi per il MacBook Air da 13 pollici rilasciato a marzo 2025, con chip M4.
MacBook clicking and cracking
I recently cleaned out my macbook air m4 keyboard with my pc blower but now its making clicking and cracking sounds everywehre whether i open it or close it or press anywhere i treat it like a gem and never damage it. i need help please.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If it started right after using the blower, I’d stop using it for now. A PC blower can be strong enough to shift something slightly inside the hinge or chassis.
Try opening and closing it slowly and listen for exactly where the crack is coming from. Also check that the bottom case screws are tight and the case isn’t lifting anywhere. If the sound happens even when you just press the palm rest or bottom case, I’d get it checked rather than keep using the blower.
Punteggio 0
2 Commenti:
Im thinking of opening up the bottom case and cleaning it out to see if that fixes the issue
da
@shayanashayeri I’d be careful opening it just to clean more. Since the noise started after the blower, I’d inspect the hinge and bottom case for anything loose first rather than blowing more air inside.
da
Aggiungi la tua risposta
Shayan Ashayeri sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 33
Tutti i Tempi: 33
