Salta al contenuto principale
Il Makita XDT08 è un cacciavite a percussione a batteria progettato per uso professionale, dotato di motore senza spazzole e compatibile con le batterie agli ioni di litio LXT da 18 V. Con dimensioni di 14,9 cm x 8,3 cm x 23,2 cm e un attacco esagonale da 1/4", offre un'elevata coppia e velocità per diverse operazioni di avvitatura e serraggio.
cracking the driver case
I need to replace the switch. I have all of the screws out but the yellow plastic peice at the bottom is preventing me from cracking the case open. I have pryed on it with a screw driver and it won't separate. I don't want to break it. How do I split this open without damage.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Yeah, I wouldn’t keep hammering that yellow piece with a screwdriver. On the XDT08, the housing is held together by eight 3×16 screws, and the parts diagram shows the housing as a two-piece housing set. The switch itself is part 650689-0.
That yellow piece you’re seeing at the bottom is probably the battery terminal/support area catching on the housing. When you separate the halves, work around the housing seam with a thin plastic pry tool and gently work the halves apart rather than prying directly against the yellow plastic. The same basic Makita housing procedure on these impact drivers is to separate the two shell halves carefully while keeping the yellow battery-terminal piece seated in the lower housing. Once you get a small gap, go around the perimeter and release the shell little by little. Don't force one spot. There may also be wiring and the controller sitting in the housing, so I'd rather spend five minutes working the seam than crack a $30-ish housing or pull a wire loose.
Punteggio 0
Aggiungi la tua risposta
Brian Taylor sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 46
Tutti i Tempi: 59
