Salta al contenuto principale
La Makita LS1013 è una troncatrice radiale elettrica a filo con lama da 10 pollici, progettata per diverse applicazioni di taglio e dotata di freno elettrico e pompetta ad aria. La LS1018 è un modello simile di troncatrice radiale doppia da 10 pollici.
How to fix locking slide
the handle tightens but does not lock
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The slide lock on a Makita LS1013 fails to lock when the clamping mechanism, threaded rod, or internal cam inside the slide assembly wears out, binds, or loses adjustment.
Common Causes and Fixes
  • Loose or Backed-Off Knob: The black slide lock knob can unthread or back off the internal rod, meaning it runs out of travel before applying enough pressure to grip the slide rails. Turn the knob fully to tighten and check if the internal linkage engages.
  • Jammed or Worn Cam: Over-tightening the lock over time can cause the slide tube or internal cam to stick or distort inside the housing. You may need to remove the assembly, clean out accumulated dust, and inspect the internal metal parts.
  • Debris and Rust Build-up: Wood dust and debris inside the slide lock channel prevent the clamping mechanism from making full contact with the rails. Blow out the area with compressed air and clean the slide poles.
Watch this video for a visual guide on inspecting and servicing the internal locking and linkage components on a Makita LS1013:
https://www.youtube.com/watch?v=9BqHLUW5...
Punteggio 0
Aggiungi la tua risposta
Barry Nissen sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 59
Tutti i Tempi: 115
