Salta al contenuto principale
Il Nexus S è uno smartphone sviluppato in collaborazione da Google e Samsung ed è stato il primo smartphone a utilizzare il sistema operativo Android 2.3 "Gingerbread".
My Home Button Touch key doesnt work
Hello guys
It think its the navigation Touch key. Or do you know how I can fix this issue?
How can I replace the Front navigation Touch Key?
Thanks for helping me if this problem
Mark
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
5 Risposte
Soluzione prescelta
this is the part this shows how to fit it. If the other buttons and touch screen are working this may solve the problem and is cheap and easy to do.
Punteggio 1
Unfortunately, the capacitive touch buttons are part of the front panel display assembly. You would have to replace the entire front panel display assembly. Aside from a hardware issue, it could also be a software issue. Is your phone stock or is it running a custom ROM?
Punteggio 0
Thanks for the quick replies. Yes i run the stock rom the Touchscreen and the other buttons are working!
I will try to solve it with this replacement.
Punteggio 0
So the parts finally arrived. I replaced the part and now the screen dont show anything.
At the begining I plugged the phone to power. It showed me the Loading Sign for 2 seconds. Now there isnt nothing on the screen. Did I forget something or did I destroyed something...?
Punteggio 0
My google nexus phone soft key home and recent application key was not working from last two days if any one help me to fix that problem?
Punteggio 0
Aggiungi la tua risposta
Marc Burkhalter sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 30
Tutti i Tempi: 3,001
