Salta al contenuto principale
La settima generazione della Ford Fiesta si è concentrata maggiormente su interni raffinati e tecnologie avanzate, includendo un passaggio verso l'elettrificazione prima che il modello venisse definitivamente interrotto. La gamma motori principale era composta dal 1.0L EcoBoost turbo a tre cilindri, un 1.1L Ti-VCT e un diesel 1.5L TDCi. Per il modello ST orientato alle prestazioni, era presente un motore EcoBoost a tre cilindri da 1,5L capace di erogare 197 CV e dotato di disattivazione dei cilindri per migliorare l'efficienza dei consumi.
Reverse not functioning after replacing battery
I changed the car battery then the reverse function is not functioning. When drivibg forward there is noticeable not smooth when during shifting
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@zacsevilla it is possible that when you disconnected the battery the Transmission Control Module (TCM) may have lost its Keep Alive Memory (KAM). Erasing that memory means the computer has forgotten the precise bite points of the clutches and the exact positions of the internal shift forks, which frequently results in a locked-out reverse gear and shuddering forward shifts.
Start of by performing a Static Idle Relearn which will force the transmission to find the baseline positions. Start the engine and let it reach normal operating temperature. With your foot firmly pressing the brake pedal, shift from Park down into Reverse, Neutral, Drive, and Low/Sport. Leave the shifter in each position for exactly 5 seconds before moving to the next. Shift back up to Park in the same 5-second intervals. Turn the key off, wait 30 seconds, and restart to see if Reverse engages.
Now, if that did not work you will most likely need to run a TCM Adaptive Relearn via OBDII You will need to connect a diagnostic interface (like an ELM327 adapter) and use software like FORScan to run the "TCM Adaptive Learning" service procedure. That maybe one of those tasks where a professional shop will come in handy. The adapter as well as the software may not be that easy to come by and/or use.
Punteggio 1
Aggiungi la tua risposta
Zac Sevilla sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 23
Ultimi 30 giorni: 35
Tutti i Tempi: 35
