Salta al contenuto principale
A1708/EMC 3164 — Pubblicato a giugno 2017, questo MacBook Pro di fascia entry-level conserva i tradizionali tasti funzione (a differenza della Touch Bar OLED).
Keyboard damage - one key
Hi guys,
One of my laptop keys came off. I had considered buying the key caps but it appears the part needed to hold the key caps is also broken off.
What do I need in this case? Please see attached photos. I can send some more of required.
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Ouch! This doesn't look good.
There's more damage than the keycap parts here! The clips are fully gone as well as the switch pieces. I don't see anyway to fix this without just replacing the full keyboard.
A good Mac tech can do this, it's not an easy repair, you might want to look at a used 2019 or newer system as the 2016 to 2018 models have had issues with their Butterfly keyboards. The 2019 have better keys.
Punteggio 0
Aggiungi la tua risposta
Eric Njogu sarĂ  eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 27
Tutti i Tempi: 72
