Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e sulla soluzione problemi per lo smartwatch Google Pixel Watch 4, rilasciato nell'ottobre 2025. Disponibile nei formati da 41 mm e 45 mm.
Screen replacement, found spring
I completed disassembly and was about to start reassembly with the new screen when I noticed a very small spring.
The spring was just sitting there magnetically attached to the watch internals, and unclear where it came from.
If anyone has any idea where it should go, please let me know
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Looks like there are springs under the two "structural guides" (not sure what else to call them) on opposite sides of the watch.
They also tie into the screws inside the watch band grooves. Each has two springs, one of mine came out.
No idea how to get the spring back in without potentially causing more damage, so I left it out and things seem to be working fine.
Here is a picture pointing out the spring locations...
Immagine
Punteggio 0
Aggiungi la tua risposta
Brian Hastings sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 54
Tutti i Tempi: 115
