Salta al contenuto principale
Annunciato il 28 settembre 2023, il Raspberry Pi 5 funge da revisione dell'hardware del Raspberry Pi 4B.
What are these black rectangular SMD elements
Immagine
What are these black rectangular SMD elements and what is the resistance of the resistors between them, thanks
Questa è una buona domanda?
Punteggio 1
1 Commento
Sadly the schematics and the full board view drawings have not been released to be sure. Here's a useful site to help you a bit: raspberrypicase
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Maybe you can find some info based on these close-up images of the area
Immagine
Immagine
Punteggio 0
2 Commenti:
That a better image than what I had found👍 I was looking for DA9081
So it's a Dialog DA9091 it looks like this chip might be the root issue as you can see in this dialog DA9091 on Raspberry Pi's site and here Renesas 9091 support. Here's a source for the chip DA9091 and it appears the chip can burn when subjected to the wrong voltage.
Still looking for the chip sheet and maybe a sample circuit.
da
The inductors you highlighted are the following spec
Inductor, SMT 0805, 470nH, IRMS=4A, ISAT=4.6A, DCR(max)=35mR
da
Aggiungi la tua risposta
Neizvestnyu sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 15
Ultimi 30 giorni: 30
Tutti i Tempi: 152
