Salta al contenuto principale
Il telefono più popolare di Apple del 2021 è stato lanciato sul mercato il 24 settembre e ha uno schermo OLED da 6,1", un sistema di fotocamera doppia da 12 MP ed è disponibile in cinque diversi colori. È il successore dell'iPhone 12.
Phone overheating causing bugs.
My phone gets rather hot, not to the point of the heat warning popping up, but when listening to music via Bluetooth the song keep jittering or proceeds to skip the song. Also when on a phone call sometimes it glitches out and makes the weird dududududuududu noise and I can hear the person in the next end or they can’t hear me. I have realized the call not glitches out when a picture is taken or I load up a game app. I told this to my local phone fixers and they said it was the battery, so they changed the battery for me, yet same problem the back of the phone isn’t as hot but the side get really hot and the music keep jittering and the phone keeps bugging on calls and lags a lot. Someone please help.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
That sounds like more than just a battery issue, especially since the battery was already replaced and the phone is still getting hot and glitching during calls/Bluetooth.
The fact that the side of the phone gets particularly hot could point to a board-level component, radio/communication circuitry, or another hardware fault. Heat can also cause performance and radio/audio problems as the phone tries to protect itself.
I'd check whether the glitches happen when the phone is cool. If they do, and you're seeing crashes/restarts as well, an iPhone panic log analysis would be worth doing. It can help identify whether a specific hardware subsystem is failing instead of replacing more parts blindly.
Punteggio 0
Aggiungi la tua risposta
Iphone13help sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 7
Tutti i Tempi: 34
