La Chrysler 300 è un’auto di lusso di grandi dimensioni, a trazione posteriore e motore anteriore, prodotta e commercializzata da Chrysler come berlina a quattro porte e station wagon.
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti:
@testemail what makes you think that you have an issue with your ABS unit? Have you got your vehicle scanned? Any error codes? What are the issues with you brakes? What exact year is your 300?
In addition to oldturkey03's question, if the abs indicator turned on and remained on, there's an error code but decoded by readers/scantools Autozone, Advanced Auto, transmission, collision and repair shops have. Not generic low cost readers. If the abs indicator cycles on and off with other indicators when turning on ignition, abs is operating correctly (power on self tests including all wiring to wheel speed sensors). Abs errors are usually C type codes.
da oldturkey03 Condividi
da F Dryer Condividi
