Salta al contenuto principale
Why can't I close my gamecube Controller shell
I decided to buy a gamecube Controller replacement shell from extremerate. But when i tried to install it . It wouldn't close! Btw I have type 3 motherboard
Immagine
pls help me 🙏
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Make sure the triggers are good aligned, otherwise it won’t close easily. Also check the rumble motor. If it isn’t inserted correctly (wrong way) it won’t close easily either.
Hopefully that is it. Otherwise try again with the original shell, if that one works right away, it’s related to the case…
Punteggio 1
Aggiungi la tua risposta
Krzysztof Horodeński sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 25
Tutti i Tempi: 25
