Salta al contenuto principale
Il Samsung Galaxy A31 è un dispositivo Android di fascia media lanciato da Samsung nell'aprile 2020. Identificabile dai numeri di modello SM-A315(F, F/DS, G/DS e G/DSL).
Not switching my phone
When iam doing charging it just vibrate it will not will not on the phone and I remove from charging and try to switch on it will just vibrate and not showing anything
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@saimashaikh "it just vibrate it will not will not on" what you are describing are the symptoms of a failed screen. Replace the display and re-evaluate.
Use something like this video as your guide. Of course you can also use the guide from here. It is written in French. Use a browser that does the translation for you, if needed. Replacement displays are readily available. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem with their device as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 0
Aggiungi la tua risposta
Saima Shaikh sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 12
Tutti i Tempi: 41
