How to replace mobile screen
Questa è una buona domanda?
It's fairly straight-forward on your phone, much the same as it is for a lot of Android phones. First thing is to take off the back panel, then unscrew the midframe retaining plates on the top and bottom. Disconnect the battery first, then the display connector from the motherboard and the lower connector on the daughter card. Separate the LCD from the midframe and remove it. Clean the old adhesive, glue on a new display with something like B7000 and reassemble. This video shows you the whole process.
Redmi 9c Lcd Screen Replacement Without Frame - YouTube
As you work, take lots of pictures and once you're done, you can use them to create your own iFixit guide to that repair. It's easy, fun, and will have the appreciation of the repair community, especially those who come after you with the same problem.
Good luck, and let us know how it all turns out!
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 15
Tutti i Tempi: 69
