Salta al contenuto principale
Guide di riparazione e informazioni sullo smontaggio per il MacBook Pro 16" uscito a novembre 2019. Modello A2141, EMC 3347.
Leftmost 512 pixels not displaying
I got this machine cheapish as the original display was smashed. The full image could be seen though. I had a spare here and it works fine except the leftmost 512 pixels which is very telling. That’s exactly 1/6 of the panel. There’s no physical damage to the display but I have noticed the lugs holding the metal covers over the ribbons down on the tcon have failed only on the innermost lugs. I suspect it’s been badly flexed at some point. My question is, could there be a tcon issue here? It feels more like that than a damaged lcd or flex gate. Never seen a flex gate lcd like this.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The LCD panels ribbon cables is likely the issue, either they are damaged or the connection to the connection to the T-CON board. Does it look like someone tried popping off the LCD panel? Can you post some pics of the areas suspected of damage?
Punteggio 0
Aggiungi la tua risposta
Joel Whybrow sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 9
Tutti i Tempi: 55
