Salta al contenuto principale
pink screen flickering problem
pink flickering screen i try to uninstall and install again my gpu its still not work
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@princedion96322 pink and flickering is commonly a failure of the LCD. Connect an external monitor to your laptop and see what that displays. If it displays normal then you know the issue will be with your LCD. If an external monitor displays the same pink screen then the issue will be related to your motherboard i.e. GPU etc. Let us know what you find out.
The Latitude 5440 Manual is also a decent service manual and page 89 will show you how to work on your LCD if needed.
Punteggio 1
Aggiungi la tua risposta
Prince dion Calapan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 6
Tutti i Tempi: 68
