Salta al contenuto principale
atf fluid level check
some sources say to check atf fluid
when car is level and fluid is at 185°
to 203°. Unable to reach that temperature except mountain driving 500 miles away. some say engine operating temperature.
car is 2019 buick envision 2.5L with
6 speed trans. also does level mean
as car sits on level surface or as car frame sits on a lift. thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Here's the repair manual page specifying the transmission fluid level check procedure.
Transmission Fluid Level and Condition Check — 2019 Buick Envision Base Service Manual ~ LEMON Manuals
From the manual:
Driving in second gear will cause the transmission to spin faster, generating more heat and raising the fluid temperature. I don't know if your car is equipped, but the manual says you can check the temperature using the Driver Information Center.
A tool like the Torque app connected to an ELM327 dongle will let you read the temperature with the car running if your DIC doesn't show it (or you don't have a DIC).
As far as being level, there isn't enough difference between sitting on level ground and sitting on a lift to matter; the frame should be level in either case unless you've done something like put oversize tires on the rear or a weird situation like that.
Punteggio 1
Aggiungi la tua risposta
gerald beauchamp sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 25
Tutti i Tempi: 125
