Salta al contenuto principale
Una fotocamera Sony della serie HX della linea Cyber-shot.
My camera have lens problem
I want to repair my camera lens because i dropped it accidentally and now when i try to turn on its just blackscreen then shutdown by itself i ask few camera shops to give a try and repair it but they dont do it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@badzz sounds like a dislodged lens. This happens commonly when the camera was dropped with the lens extended, knocking it off the guides. Check the space around the lens and see if the spacing is equal distance all the way around. You can always try some of the recommended fixes listed on here. If none of those work, you may have to replace the lens. Use the Sony DSC HX20V HX30V Service Manual to work on it.
Punteggio 1
Aggiungi la tua risposta
badzz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 24
Tutti i Tempi: 139
