How to remove engine light
Questa è una buona domanda?
Assuming you're referring to the Malfunction Indicator Light (MIL) - more commonly known as the "check engine" light - you will need to scan the car's computer to find out what set the light on, then fix whatever is wrong with it and at that point you can safely reset the light so it doesn't just come right back on again.
Here in the US, most auto parts stores will scan your car's computer for free; they're hoping to be able to sell you parts, of course. Otherwise, there are plenty of sources for inexpensive OBD-II scanners available online; you can get them as cheaply as under $5 USD for a bluetooth dongle that connects to a free app you can download on your phone. Look for an ELM327 compliant dongle then you can go online and find an OBD-II reader app; most of them that do basic scanning and resetting of trouble codes are free; I personally use one called Torque.
So get your car scanned however you can, then come back and give us a list of any and all trouble codes you find. At that point we can probably point you in the right direction regarding what you need to do to fix the problem.
AutoZone will connect the reader and scan the codes for free. They'll even provide you a printout of the codes and the most likely suspect part to fix it. Keep in mind that they sell parts so they're really eager for the diagnosis to suggest a part they sell to repair: fair enough. While that may be exactly the fix, before making the purchase, step back and use AI to ask about the codes or even upload the printout and ask AI what the problem might be. I use grok for this sort of thing and it's always helpful.
While you're at it, ask AI for local shops that can do that specific job based on value, ratings, and positive comments. Call the identified shop and ask about the parts and labor rate to do what is needed. Ask if they will do the work if you provide the parts because RockAuto often has exactly the same parts for half the price if you have a few days to wait.
If you do take it to a local shop for the repair DO NOT TELL THEM TO REPLACE THIS OR THAT PART. Ask them to read the codes and provide their diagnosis. Only then agree or disagree on the parts they suggest replacing because your diagnosis may be wrong. (Often, it makes sense to replace a hard-to-reach part while the labor to take things apart it is already done.
If it does appear that parts are needed, I'd search youtube for a how to video on how to do the job. There's a good chance you'll find several videos so watch them all and decide if you're up to the job. Many such videos seem to be mechanics making the seem job way more difficult than it is for some reason. Others get straight to the point or provide time saving tips. By watching several you'll land on the simplest way to do it and have a good info to determine if you're up to the task.
All of this takes time, but it can be worth it if the stars align. If you need the car right away or don't have the time, you may need to just ask AI for that reputable shop and open your wallet. At least these steps make you an informed consumer.
P.S. Because I had plenty of free time, last week I replaced all 6 fuel injectors on my 2010 Ford Edge 3.5L V6. I found OEM parts on RockAuto for almost exactly half the price of everywhere else. It took 3 hours of research, $40 in new tools, and about 2 hours of my free labor.. Whole job cost $400 in parts/tools and it would have been $900-$1200 at the shop. It's getting 35% better gas mileage now than it was before the problem arose and I have cool new tools and a happy wife.
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 67
Tutti i Tempi: 225
