Salta al contenuto principale
Lo Xiaomi Redmi 10 5G è uno smartphone Android 5G entry level rilasciato a marzo 2022. Offre un display LCD IPS da 6,58", una batteria da 5000 mAh, una fotocamera principale da 50 MP e utilizza un chipset MediaTek Dimensity 700.
Phone Vibration not working
Phone vibration not working
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
  • First, restart your phone.
  • Go to the Phone Settings and check the vibration intensity and toggle switches (On/Off).
  • If it still doesn't work, you need to check the vibration motor. This is often caused by a loose connection/cable; the motor itself rarely fails.
Punteggio 0
Well restart you phone and then check if the issue remain or not if yes the issue remain then check for the software version sometime outdated software version can also be the reason of this kind of issue so make sure that your phone is updated to it latest and stable software version.
Punteggio 0
virus problem no open security and accessibility service please find my issue
Punteggio 0
Aggiungi la tua risposta
Gaurav Raj sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 37
Tutti i Tempi: 229
