Salta al contenuto principale
Modello A1297 Unibody: inizio 2009, metà 2009, metà 2010, inizio 2011 e fine 2011
How to Install SSD
I want to install a SSD into my MacBook Pro 17. I bought a Mercury Electra 3G SSD. How do I install it into my MacBook Pro? It didn't come with directions, although they told me it would work.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione prescelta
I just installed a second hard drive in the place of the optical drive in my MacBook the other day! It's pretty nice having the extra capacity.
Even if you just replace your current hard drive with your SSD, you'll see a significant speedup.
Here are the relevant guides:
Replacing the current hard drive:
Sostituzione hard drive del MacBook Pro 17" Unibody
Removing the optical drive:
Sostituzione unità disco ottico MacBook Pro 17" Unibody
Go to the last page of this guide on replacing the optical drive (it's for my machine, but the last page would help for installing the second drive)
Installazione dell'SSD Dual Drive nel MacBook Core 2 Duo
And finally, the part that iFixit sells for the second hard drive:
[prodotto collegato mancante o disabilitato: IF107-080]
Good luck and enjoy your SSD!
Immagine MacBook Pro 17" Unibody Hard drive
Guida
Difficoltà:
Moderato
15 - 30 minutes
Immagine MacBook Pro 17" Unibody unità disco ottico
Guida
Difficoltà:
Moderato
1 - 2 hours
Immagine MacBook Core 2 Duo Doppio hard drive
Guida
Difficoltà:
Moderato
1 - 2 hours
Punteggio 1
Risposta più utile
You either have to: 1.) replace your current HDD with the SSD or 2.) remove the SuperDrive CD burner and replace with your current HDD and put the SSD in the original place that the HDD was in. The latter is the most popular because you can still use the SuperDrive via USB by purchasing external case for the SuperDrive and you just plug and play with the USB, therefore having a HDD and SSD. Also, with the latter, you must purchase an OptiBay expansion kit to be able to place the HDD into the SuperDrive bay.
Punteggio 1
Aggiungi la tua risposta
dconkright sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 25,984
