Power cut and not working
Not working. Power cut
Questa è una buona domanda?
Like @rodolfomeave, I'm not familiar with your particular vacuum, but I had the same issue with a Harbor Freight shop vac.
By testing the power going to the fan motor, I finally isolated it to a failed thermal fuse on one of the motor leads. These are designed to blow when the temperature exceeds a particular limit, but I have no reason to think mine was anywhere near that range when it blew. Anyway, replacing the fuse got the vacuum up and running again and I haven't had an issue with it since. Here's the part I purchased; yours will probably look similar, although you'll need to use the markings on it to determine what value to use for a replacement.
Good luck, and be sure to come back and let us know what you find!
I do not have a Henry Vacuum, but if you are still having power issues there are some troubleshooting checks that you can do:
Hopefully this helps!
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 32
Tutti i Tempi: 152
