Salta al contenuto principale
Il Dell OptiPlex 360 è una soluzione desktop economica, costruita con funzioni pratiche incentrate sull'offrire un valore aziendale essenziale.
Sound is not coming
Sound is not hearing by us and not audible
Questa è una buona domanda?
Punteggio 0
1 Commento
Is there any audio built in? if not its possible that you need speakers or a screen that has speakers built in before you get any sound.
da
Aggiungi un commento
1 Risposta
Risposta più utile
@muhammadra94899 you are not telling us what you have already tried and what you have already checked. You are also not telling us what OS you are using. I assume some Windows version.
First, you want to make sure that your onboard audio is enabled. Restart the computer and tap F2 to enter BIOS. Scroll to "Integrated Devices" or "Onboard Devices". Make sure that Sound or Audio is set to Enabled. The save and exit.
Next, check your Windows Audio settings. Click the speaker icon in the bottom-right corner and select the correct playback device (e.g., "Speakers/Headphones" or your monitor name. whichever device you are using to receive Audio). Next check to make sure the volume is turned up and that is not muted.
After that, you want to update your audio driver. Go to the Dell Drivers & Downloads page.Select your operating system (e.g., Windows 7/10).Download and install the Audio Driver (usually Analog Devices/ADI).
Of course, make sure that you have speakers connected and that those are working as well.
Punteggio 1
Aggiungi la tua risposta
Muhammad Ramzan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 11
Tutti i Tempi: 122
