Salta al contenuto principale
A1708/EMC 3164 — Pubblicato a giugno 2017, questo MacBook Pro di fascia entry-level conserva i tradizionali tasti funzione (a differenza della Touch Bar OLED).
MacBook battery cable Problem
Hello, I have a 2017 MacBook Pro 13-inch. I recently replaced the screen, and after the repair, the laptop would not power on unless it was connected to a high-wattage charger. It does turn on with the AC adapter, but there is an “X” over the battery icon, and if I unplug the charger, the laptop immediately shuts off.
I suspect the issue may be the battery ribbon cable, which I’ve already ordered, but I wanted to see if anyone else has experienced this or knows what the problem might be.
Thanks in advance!
Immagine
Questa è una buona domanda?
Punteggio 0
1 Commento:
Looking at the picture (left side connection) the cable isn't pushed into the connector and latched down.
da Condividi
Aggiungi un commento
1 Risposta
Double check the ribbon cables ZIF connectors as often the compression latches are not properly set so the connection is not making good contact. Review the steps 11 & 12 in the Sostituzione batteria MacBook Pro 13" Function Keys 2017 jump between two images of Step 11 note the lifting of the latch. Make sure the latch is reset pressing it down once the ribbon is squarely in place on both ends.
Punteggio 0
Aggiungi la tua risposta
Frank I sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 154
