Power button not working it went inside
Power button not working and went inside
Questa è una buona domanda?
Hi, @naraharise87483 I gotchu.
I would say to use some tweezers from a Precision Tweezers Set and try tweezing the power button out.
Also try opening the phone and locating the power button.
The phone's fingerprint sensor is not working.
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 90
Tutti i Tempi: 334
What happened to the power button? Went inside where? More info would be useful when trying to get help.
da someperson
@somerandomguy_1 If I had to guess, I'd say they mean that the power button is stuck, but yeah, more information would help.
da Fixer of Stuff
@fixerofstuff Good point. @naraharise87483, does the button feel like it's jammed by dirt, or did it sink in after a drop? If the button still "clicks", you might want to use Isopropyl alcohol on a Q-tip to clean it; otherwise, the motherboard might have shifted inside the case, causing the button to get stuck underneath the screen.
da someperson
