Salta al contenuto principale
Pubblicato a ottobre 2023, utilizza una CPU Rockchip RK3326.
it's stuck on loading screen
idk why everytime I open it it's just stuck on the loading screen, maybe bc the SD card is corrupt
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @minecraftjava
Try a power refresh and check if that resolves the problem.
Turn of the device (if it is on) and then remove the battery cover on the back of the device and remove and disconnect the battery from the motherboard.
Here's a video that shows what to do.
Press and hold the power button operated for a full 30 seconds and then release it.
Reconnect the battery and reinsert it into the device, replace the battery cover and check if it now turns on OK.
Punteggio 1
Aggiungi la tua risposta
Minecraft Java sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 100
Tutti i Tempi: 362
