Salta al contenuto principale
Guide di riparazione e supporto per la quarta generazione di Chevrolet Caprice, una berlina full-size a motore anteriore e trazione posteriore. Strettamente imparentata con altre auto GM B-body come la Impala SS e la Buick Roadmaster.
Car cut off while driving
Car drive but cut off
Questa è una buona domanda?
Punteggio 0
1 Commento:
Is the car shutting off when the gas is pressed, or when coming to a stop? What year model is it?
da
Aggiungi un commento
1 Risposta
First step is too determine if the problem is fuel related or ignition. Start with a code scan and solve any engine related codes. If that doesn't fix it then when the engine dies, check for spark, if you have no spark fix that problem. It could be the module, the reluctor, the cap or rotor, the ignition coil, ignition wires even the spark plugs.
If the engine has spark when it dies, put a fuel pressure gauge on the engine. If the engine quits and has no fuel pressure then the problem is the fuel system. It could be the ECM, wiring, relay, fuse or the pump.
Obviously this diagnosis if not for the faint of heart nor the uninitiated. Your best bet may be a mobile mechanic. The car is rather old so an older mechanic may be more familiar with your cars systems.
Punteggio 0
Aggiungi la tua risposta
Mike Jones sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 11
Tutti i Tempi: 104
