Salta al contenuto principale
L'Oppo Reno7 5G è uno smartphone progettato da Oppo. Il telefono è stato rilasciato nel 2022.
Phone not getting charged
I was putting my phone on charging with other charger when I started charging it doesn't start charging it gets off and know it is not open after connecting to it's charger also so what happened to it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
It's hard to parse your message but I guess you are saying, your phone does not charge? Some things to try:
Test if other devices will charge with your cable and charger. If not:
  • Try a different USB-cable
  • Try a different charger
If that does not help, have good look at the charging port of the phone: does it look dirty or bent?
When you connect your phone to a computer, does it charge? Is it recognized by the computer?
Maybe try rebooting the phone.
Punteggio 0
Well I think your battery is dead and you need to replace your battery with the new battery.
Punteggio 0
Aggiungi la tua risposta
Yatharth Kakad sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 125
