Salta al contenuto principale
Specifiche tecniche del modello 2023 di Infinix Note 12 È stato rilasciato il 6 ottobre 2022. È dotato di uno schermo da 6,7 pollici, AMOLED, con una risoluzione di 1080 x 2400 pixel. Utilizza un chipset MediaTek MT8781 Helio G99 (6nm), una CPU Octa-core (2×2,2 GHz Cortex-A76 e 6×2,0 GHz Cortex-A55) e una GPU Mali-G57 MC2.
Phone camera not working
Kaise thik kre
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Yes it is not working I don't know why
da Condividi
@merryjoymeneses you are not telling us what is not working and what you have already tried. Did you read and follow the original answer? Any success?
da Condividi
Hi my camera phone broke. Can you help me this?
da Condividi
Aggiungi un commento
1 Risposta
@moanas you have not told us which camera has failed. The very first thing you want to do is to try using your camera in Safe Mode. If it works in safe mode, you know that the issue is a Third-Party App that prevents access to your camera. You will have to uninstall that software.
To enter Safe Mode, hold the power button, then press and hold the "Power off" option on the screen until the "Reboot to safe mode" prompt appears. Select OK to restart in safe mode
Now, if it does not work in safe mode as well, it could very well be that the camera module has failed. Since iFixit does not yet have any guides for this, use something like this video to work on replacing the camera module.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 0
Aggiungi la tua risposta
Mo Anas sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 52
Tutti i Tempi: 285
