Salta al contenuto principale
Annunciato il 28 settembre 2023, il Raspberry Pi 5 funge da revisione dell'hardware del Raspberry Pi 4B.
Change PCIe plastic clip
I broke one side of the plastic clip which keep in place the FFC cable, is there a way to replace just the clip and not the entire PCIe connector? I was able to push the clip back inside and for now seems like it could stay in place and the nvme hat it's working but better safe than sorry
Aggiorna (04/08/26)
Immagine
it’s the circled brown clip
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Can you post a nice sharp image so we can see the connectors details.
da
Yes sorry, I updated the question with a photo
da
Aggiungi un commento
1 Risposta
Well from what I've discovered this as an amphenol connector 62674-161120ALF which sadly is no longer made. Instead this might work F31W-1A7H1-11016
Here's the parts schematic of the original to help guide you. Carefully you should be able to tale the new part apart to salvage the latch
62674 Connector. Otherwise you'll need to desolder the connector to replace it with the alternate connector..
Punteggio 0
Aggiungi la tua risposta
Matteo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 14
Ultimi 30 giorni: 45
Tutti i Tempi: 287
