Why wont my iPhone turn on
my phone was recently dropped into a pool and i dried it as much as i could without taking it apart and now it only works when it is plugged in any advice would be much appreciated
Questa è una buona domanda?
With any immersion you should always clean your iDevice. If you do not clean it properly, you are running the risk of later failure due to corrosion. Check this guide for that. Even so it was written for a 3G it all still applies to your phone. Just as The tinker says, replace the battery as well.
You're very lucky your Iphone is still working.
Your battery was not the same lucky I guess:
You'll have to change your battery which is dead, you've two options:
-Use apple care that will steal you 80$ and will take 2 weeks
-Do it yourself, that will cost you 20-30$ and will take 30 mins
I let you choose the good option ;)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 338
