Salta al contenuto principale
Extreme low screen brightness
I cannt see anything on the screen clearly.I conneted the labtop to a projector and adjusted the bightness to 100% but still nothing changed when i disconnect it from the projector
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If your laptop screen is very dim or unclear even at 100% brightness, the issue is likely hardware-related. Since it displays fine on a projector, your GPU is working. Common causes include a faulty backlight, damaged LCD panel, or loose display cable. First, restart and check brightness using keyboard shortcuts. Update display drivers to rule out software issues. Shine a flashlight on the screen—if you faintly see content, the backlight is failing. Try gently adjusting the screen angle in case of a loose cable. If nothing improves, you’ll likely need a screen or backlight replacement by a technician.
Punteggio 0
Aggiungi la tua risposta
Oola francis sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 14
Tutti i Tempi: 68
