Where is the O2(lambda) sensor?
When check it in INPA, lambda voltage is constant. I want to be sure if it is connected, after being sure that it is not possible to fix connections I am planning to change it.
Questa è una buona domanda?
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 125
@orkunarabaci we need to know the exact year and model as well as the engine size. The oxygen sensor is usually located in the exhaust pipe, downstream from the exhaust manifold.
da oldturkey03
316i Compact 1999 M43B16
da Orkun ARABACI
