Salta al contenuto principale
Any guides to replace the casing?
I've been using my aspire 515-56 for a long while, and the case has become a liiiitle banged up with use. I'm talking multiple cracks 'n such--not to the point of being unusable, but I'd like to at least be prepared just in case. No other problems for now, it's just the casing.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
@cryptid87031 the Acer Aspire A515 52 Repair Guide should still work for your model. Some of the hardware was improved but essentially the case should still disassemble about the same way.
Punteggio 2
Hi, @cryptid87031 I gotchu.
I think you can take off the screws, then take off the casing part you want to replace. This is the replacement part.
Punteggio 1
Aggiungi la tua risposta
Cryptid sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 19
Tutti i Tempi: 129
