Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e soluzione problemi per l'Apple iPad di nona generazione con Wi-Fi, disponibile con 64 o 256 GB di spazio di archiviazione. Rilasciato a settembre 2021. Identificabile dal numero di modello A2602.
Ghost touch without Digitizer connected.
Pretty much, I was repairing an iPad that was cracked and got a new digitizer, After connecting the new screen the iPad developed ghost touch and even with digitizer all disconnected it was still going crazy.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
hey look at this one the last coment realy helped me
Ghost touching WITHOUT the digitizer connected!!
here is what it said
As a professional iPad refurbisher I can tell you that ghost typing on a 9th Gen. (or 7th or 8th) in my experience has caused by digitizers that are not properly seated on the motherboard FPC connectors, (more likely on the one in the left).
The other causes can be bent or missing pins on either of those FPC connectors which can be caused by pressing too hard when trying to seat one or both connectors,
The third possibility is a defect in the digitizer itself other than either of the connectors.
Punteggio 0
Aggiungi la tua risposta
joseph jackson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 35
Tutti i Tempi: 164
