L'Explorer del 2011 di quinta generazione presentava similitudini con la costruzione del concept Explorer America e include una struttura unibody basata sulla piattaforma D4.
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento:
I wouldn't suggest resetting the airbag light unless you've actually fixed whatever problem caused it to turn on in the first place. Did you determine what turned it on, and if so what was it?
With regard to the key fob, has it ever worked? Is this a fob that came with the Explorer or one you bought? You replaced the battery first thing, right?
da Jerry Wheeler
