Salta al contenuto principale
Guide di riparazione, manuali e aiuto per la risoluzione dei problemi per Mercedes-Benz w203. Ottieni tutto il necessario per riparare da solo il tuo Mercedes-Benz w203.
Engine check light is on?
Why is the Engine check light is on?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
My English might be unnatural, sorry.
1. Intake manifold variable mechanism (P2004) trouble
Failure where the intake manifold flap stays open
An actual case of P2004 occurred in a W203 C230
Intake efficiency gets disrupted → air-fuel mixture becomes rich → P2188 / P2190 may also appear simultaneously
2. Issues related to rich fuel (P2188 / P2190)
O2 sensor deterioration
Air intake leak (hose crack)
Mass air flow (MAF) sensor failure
In actual W203 cases, replacing the MAF improved the issue
3. Purge valve failure (common)
Valve that controls gasoline evaporative gases
In a W203 C180, the check engine light was caused by the purge valve
A part prone to failure considering the model year
4. Oil leak from cam magnet (cam actuator)
A common problem in W203 cars
Leaked oil travels along wiring and reaches the ECU → sensor malfunction
There are cases where oil reached the ECU via wiring, causing multiple errors
Needs prompt attention as leaving it untreated can worsen the problem
5. O2 sensor failure
Frequent in Mercedes in general
Causes poor fuel economy and unstable idling
Listed as a common issue in Mercedes vehicles
Punteggio 0
@jonvi90986 there are to many possibilities. Get the OBDII scanned and see what codes it will show. That way you know for sure what is going on with your MB. If you are somewhere in the USA, AutoZone etc. offers free scanning and it will definitely be a good start.
Punteggio 0
Aggiungi la tua risposta
Jon Vi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 17
Tutti i Tempi: 150
