Salta al contenuto principale
Lenovo LOQ 15IAX9 con Intel i5-12450HX, GPU fino a RTX 4060, display FHD 144 Hz da 15,6″, fino a 32 GB DDR5, SSD PCIe Gen4, batteria da 60 Wh e I/O completo, inclusi HDMI 2.1 e USB-C.
How do I reset BIOS.
When i was downloading GPU Drivers, it said that something went wrong. So i got to BIOS settings and turned GPU from Hybrid to Discrete. My screen went black, never turned on again, fans are spinning, keyboard lights up, just black screen. Tried resetting CMOS battery, tried disconnecting main battery too and also tried hard reset, nothing worked. Can y'all help me? Thanks.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Turn off the laptop, then turn it on and repeatedly press F2 (or Fn+F2) to enter the BIOS menu. Navigate to the Exit tab, select Load Setup Defaults, confirm with Yes, then select Save & Exit. Hope it works!
Punteggio 0
I also had a similar thing happen when changing any setting or updating bios, if it looks like it is boot looping trust that because it looped 5, maybe 6 times before the screen lit up for me after a bios update. It's scary but eh, I guess I can deal with it... If it didn't try to restart either your GPU might not be getting to the screen and in that case I'd just hold down f2 during boot and disable discrete mode, it's no use downloading a GPU driver if it's gonna stop functioning...
Punteggio 0
Aggiungi la tua risposta
Giorgi Abramishvili sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 16
Ultimi 30 giorni: 84
Tutti i Tempi: 806
