Salta al contenuto principale
La Sony Cyber-shot DSC-W55 è stata presentata all'inizio del 2007. Rispetto al modello precedente, dotato di una fotocamera da 5,1 megapixel, questa versione è stata aggiornata con una fotocamera da 7,2 megapixel e dispone di 56 MB di memoria interna.
My Lens does not focus.
My son dropped my DSC-W55 and now while focussing, I can see blurred images. But if I gently push the lens from outside, I can focus clearly. But if I try autofocus, then due to the lens movement, the lens defocuses again. I need to repeat the 'Push' action every time I need to click a picture. Can someone Help me get it resolved? I took it to the Repair centre, they wanted me to change the entire Lens unit, but I believe there should be some fix, other than replacing the unit. THANKS !!
Questa è una buona domanda?
Punteggio 1
2 Commenti
Would you be comfortable to disassemble your camera right down to the lens block itself?
da
Yep. I would be happy to disassemble if I could get it fixed. I wanted to check if there was any minor problem.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
TKS, download the service manual from here. Scroll down to Service Documents and click on the links. It will show you all the details and should help to trouble shoot. Hope this helps,good luck.
Punteggio 1
1 Commento:
Minha máquina não liga mais e parou do nada. O que pode ser?
da
Risposta più utile
Hello,
Your camera uses several other factors when auto focusing including infrared or sonar. It sounds like when your son dropped it, You may have jarred one of these sensors. Replacing the lens is an option that i would use last.
My suggestion to you. Manually focus the lens to extend then gently wiggle it back and forth to allow it to recenter in the tube. It retracts and may have been shaken off track.
Punteggio 2
1 Commento:
@Gametech. Thanks .. I will try the suggested fix. But do you want me to open the Camera and do this?
da
Aggiungi la tua risposta
TKS sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 44
Tutti i Tempi: 9,815
