Salta al contenuto principale
Il telefono è dotato di un display touchscreen da 6,50 pollici con una risoluzione di 720x1600 pixel, una densità di pixel di 269 pixel per pollice (ppi) e un rapporto d'aspetto di 20:9. L'Oppo A53 2020 è alimentato da un processore octa-core Qualcomm Snapdragon 460 da 1,8 GHz. È dotato di 4 GB di RAM.
Camera front not working
Camera not working
Questa è una buona domanda?
Punteggio 1
4 Commenti
We need some more info: does the camera app open normally? are you getting an error code? when did the problem start? does the rear camera work? does the phone have any other issues?
da Condividi
@teardowns101 been there, done that (for years). Feedback and clarifications very seldom happen with this type of questions. You will find that most of these actually get totally abandoned. Go ahead and answer those with the best possible solution that you can think off when you read those question. Somebody else may actually benefit from your answer. You can always amend or edit your answer if additional information from the OP becomes available.
da Condividi
@oldturkey3 haha, you're right, I guess I'm just an optimist at heart! Good point about providing a solution for others---I've gotten help on the forums before from reading answers to other people's questions, even if the solution didn't work for them!!
da Condividi
@teardowns101 same here. That is why I think we do need to cherish and reward those OP's that are coming back and interact etc. It makes up for the many that don't. It can get pretty frustrating when you want to help someone and then there is no feedback. Don't let it discourage you and keep on trucking along ;)
da Condividi
Aggiungi un commento
4 Risposte
Risposta più utile
@samsunga2117500 start your phone in safe mode. You do that by pressing and holding the power button, then tap and hold "Power off" on the screen until a "Reboot to safe mode" prompt appears. Tap "OK" to restart. You can also turn off the phone, turn it on, and hold the volume down button when the logo appears.
Once in safe mode see if your front camera works. If so then you have a 3td p[arty App that is blocking regular access to it. You would need to uninstall those 3rd party Apps. There is no certain way to determine which App so you would start be deleting one after the next 3rd party App.
If your camera even in safe mode does not work, then the issue is most likely with the camera itself. You may need to consider replacing the camera model. Since iFixit does not yet have a specific guide for that, use the teardown from here to work on it. Of course, you do not need to remove the charging board etc. The camera modules are readily available.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 1
الكاميرا الامامية عندي معطلة
Punteggio 0
https://youtu.be/s-ebktoSLgo?si=LBiqaR8d...
Punteggio 0
Front camera white screen
Punteggio 0
Aggiungi la tua risposta
Samsung a21s sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 20
Ultimi 30 giorni: 43
Tutti i Tempi: 388
