Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Domande Visualizza tutte
Screen Cover ( i.e bit with Apple Logo ) Seperating from LCD
Hello,
I cant find any guide to assembly of the LCD part of the MacBook Pro. The 'top cover' of the LCD on mine was never perfectly straight and recently its popped off on one side. It looks like its just glued on when i push it down it looks pretty much normal.
Any ideas ?
Cheers Alex
Picture : http://img6.imageshack.us/img6/2408/img0...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If still under warranty I would take it in, else wise:
The glue used is heat activated. If it will go back together I would use some "C" clamps (Home Depot has some with rubber feet) and some adhesive: Fix-All Adhesive is a great all-purpose solvent glue and sealer. It seals and repairs almost any surface easily and quickly. http://www.supergluecorp.com/super-glue/... FixAll
Punteggio 3
2 Commenti:
Good answer. +1 Ralph
da
Hi, No warranty i am afraid as i bought it just after it came out. I will give your idea a shot. I just wanted to see if this was the way it was orginally held together before ploughin ahead
da
Aggiungi la tua risposta
Alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,832
