Traction sensor of range
How can i fix inflate sensor
Questa è una buona domanda?
Punteggio 0
5 Commenti:
@emmanuelva68867 not quite sure which sensor you are referring to. Do you mean the Tire pressure sensor?
da Condividi
da Condividi
No, I was told on a Chevy Malibu 2016 eco-friendly that there was a transmission sensor that was like a $50 part that you could get and replaced
da Condividi
@kassandrek55166 let's try and narrow this down since there are actually a few transmission sensors as well. What is going on with your Malibu? Give us the complete symptoms.
da Condividi
Okay, when you pull up to a stoplight and the light turns green you press the gas cuddle and the RPMs do not raise the speedometer is not move. You can have the gas pedals all the way to the floor and it will not move and then about 10 to 15 seconds depending on its mood. It will kick in and you'll be able to drive the car again
da Condividi
Aggiungi un commento
