Salta al contenuto principale
La GeForce GT 1030 è stata una scheda grafica entry-level di NVIDIA, lanciata il 17 maggio 2017. Realizzata con processo produttivo a 14 nm e basata sul processore grafico GP108, nella variante GP108-300-A1, la scheda supporta le DirectX 12.
When playing game it makes glitches
When I play games it glitches and automatically log out from the game
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta più utile
Since your using a GT 1030, first thing I'd rec is to fully uninstall and reinstall your GPU drivers. If that doesn't help, and you carry the necessary expertise, you can try repasting the card. If neither of these solutions helps, I'd recommend you look at some other fixes or replace it as it's an old budget card from circa-2017.
Punteggio 1
@mpholufela sounds like an incompatibility between the games and the graphics card. We will need to know what games you are trying to play on your GeForce GT 1030. Most likely, you will need to either play games that are less demanding on the hardware or get a better graphics card.
Punteggio 0
Aggiungi la tua risposta
Mpho Lufela sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 25
Tutti i Tempi: 180
