Salta al contenuto principale
Blue screen of death
Says bd705349 dcl and such
Immagine
Questa è una buona domanda?
Punteggio 0
1 Commento
[image|3935181]
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
This is bad, very bad. Your machine lost key data on the TPM and now it wants a 48 character Bitlocker key, one which lost means complete data loss unless you can recover the key. See if you can get the key from this site if you used a MSA: https://account.microsoft.com/devices/re... -- if you used a local account, you're done unless you have a copy of the key locally.
If you can't get back in, use this guide to make a bootable drive: Windows 10/11 - Creazione del Supporto di Installazione USB (Rufus) or Windows 10/11 - Creazione supporti installazione USB (Microsoft MCT)
If you want to be sure sure the drive is clean, use this to securely wipe it: Diagnosi e cancellazione di SSD ed eMMC - distribuzioni basate su Debian, versioni Parted Magic Legacy e 2026+
I have seen this on the 64X G9 and G10 series (not my G11) but you probably should buy a mouse... Some Synaptic chips do not work well in the installer, and my HP G9 series machines were there, G6 and older weren't affected and G11 fixed it again.
Immagine Windows 11
Guida
Difficoltà:
Facile
30 minutes - 1 hour
Immagine Linux
Guida
Difficoltà:
Facile
1 - 6 hours
Immagine Windows 11
Guida
Difficoltà:
Facile
30 minutes - 1 hour
Punteggio 3
I HAVE NO KNOWLEDGE OF BITLOCKER AS I HAVE NEVER USED IT
According to the image provided, you need to enter a security key. Microsoft says at aka.ms/myrecoverykey, you can find the key at https://account.microsoft.com/devices/re... if it was linked to your Microsoft account. If it was linked to a work or school account, go to https://aka.ms/aadrecoverykey. Printout and USB drive options are available so I would look for any items. If you cannot access or find your key, you will have to reset your computer which will erase all of your data.
I’m sorry if this does not work or the outcome has disappointed you, I’m only young (teenage), or if it has you are very welcome.
Punteggio 0
Aggiungi la tua risposta
Casey teska sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 21
Tutti i Tempi: 228
